jeff_stroh's avatar
jeff_stroh
4 years ago
Query for Items related to the current user's Identity?
Looking to build a TGV for our users that basically looks for certain ItemTypes that they are either a creator, owner, or manager of.
Trouble I'm running into is how to set the initial Query condition?
I tried setting a Where condition of Current = Name, but that didn't work.  Do get results expected when I set a parameter and then execute the query using Name LIKE $first_name...
I will be launching from a method, so I presume that could merge it into the startConditionProviderParam = 'startConditionProvider=ItemDefault({"id":"id"})'; segment, but I was hoping there was a way to do this from the Query itself.
Has anyone done something similar?
  • Good day.  Is your problem getting the current user so you can run the query from that?  Here are a couple of things in my system that pull current user info.
    C# var currentUserId = inn.getUserID();
    JavaScript var userID = aras.getCurrentUserID();
