Hi Kamran,
which report engine to you plan to use?
- XSLT (the one you get out of the box)
- SQL Reporting Service
XSLT is unfortunately very hard to customize. If you have a subscription, ask Aras if they have a template!
If you have a subscription, maybe also wait for Innovator 24. In this version Aras adds a new reporting service based on Query Definition. Much easier to customize than XSLT and more secure that SQL.
Does anyone else know more?
- kaftab14 years agoCreator I
Hi Angela,
Thanks for your detailed response. We are at the moment on an older version. We may wait till our upgrade before we implement effectivity.
I suppose Aras is reading this. We do have subscription, however, I don't expect them to provide a template (if they have any). I will have to push for it.
Thanks again,
Kamran Aftab
You said you use an older version. How old?
They current versions (>12SP7) have an Export to Excel button in the BOM Structure tab. Not a real report, but at least some solution to export the effectivity result.
In latest Innovator version Aras improved this feature so you get xlsx instead of the xls.
I was referring to the new reporting tool. We are on 12SP14, kicking off the upgrade project tomorrow [emoticon:c4563cd7d5574777a71c318021cbbcc8]
Excel export does not work for us. It does not include the top item for one, and it is not customizable like the Multi-level BOM report is. We are trying to get something from Aras Support in the way of an XSLT template, or anything else.
Thanks for your suggestions.
Kamran
