8 years agoCommunity Manager
It may be possible to call this code from an onFormPopulated form event which is called every time the form is reloaded including after a save. However, I'm not sure if it's possible to in the context of the event whether or not it's being called as the result of a save.
Would you be able to provide more details of your use case? It may be possible to get the desired result in a different way.
