Found it. There is an Itemtype Revisions on the TOC, you open that up and edit it.
Could you be more specific? I noticed that major version currently maxes out at Z. I cannot make a revision like AB, AC, AD, etc..
- Sithen6 years agoIdeator III
Append to the list.
ex: a b c ... z aa ab ac ad and so on
- dmanresa6 years agoIdeator III
Sorry, I am newbie. Do I have to change the source code or it something that can be done through web access?
Log into Innovator with Admin rights
Under the TOC expand Administrator
Find the Revision Itemtype (if you don't see it you will have to add it to the TOC)
Search Revisions (Should bring up 'Default')
Open and Edit 'Default' Itemtype
In the 'Revisions' textbox append to the list of existing revision numbers that you wish to have.
Save Lock and Close
Should now be able to revision past 'Z'
