- Former_MemberAccelerator IIIOK,Thanks.
- christopher_gillisCommunity ManagerHello, If you have enabled windows authentication and you are trying to sign in as a windows authenticated user, you can skip the login screen by using the 'bypass_logon_form' parameter (localhost/.../default.aspx. However, it does not appear to be possible to skip the login screen with the username and password if the user is not windows authenticated. Chris _______________________ Christopher Gillis Aras Labs Software Engineer
