Hi cogres, thanks for the answer.
The dialog opens from other item form, not from my in basket menu/grid.
This dialog has worfklow vote options, and when an user select one of these options, a method is executed completing a workflow task. The problem is, when that task is completed, my inbasket grid view is not updated, the task still remains viisible in the grid, the user must to run a search on my inbasket view to update, and then the task disapear, because is completed. I want to know if is possible to execute a search to update my inbasket grid automatically after the dialog is closed or a method is executed.
Regards,
Jonatas
Hi Jonatas,
okay, I see. I would still say that something like
var topWindow = aras.getMostTopWindowWithAras(window);
var workerFrame = topWindow.work;
if (workerFrame && workerFrame.searchContainer) {
workerFrame.searchContainer.runSearch();
is what you are looking for. You just need to identify the correct object in your setup that holds the right searchContainer and then run runSearch() on it.
Without knowing more about the exact nature of the setup, I can't say much more. How do you access the "My InBasket" grid from the "other item form"? On a relationship tab?
It is definitely possible to run a search for a grid on a relationships tab in a client side method, with similar to the above code.
Cheers,
C
I've recorded an example of the scenario, hope that help to demonstrate the problem:
https://www.youtube.com/watch?v=c0UGkl7DSYs&feature=youtu.be
Regards,
Jonatas
- cogres7 years agoCreator III
Hi Jonatas,
Thanks for the clarifying video! I think what you could do is the following:
You could set an onUnload JavaScript method on the form that you open in the video under "Form Events":
In that JavaScript method you need to include the following line of code:
aras.getMainWindow().work.searchContainer.runSearch();This should make it so that when you close the form shown in the video, it should run the search for "My InBasket" automatically.
Note that if your client side method contains only that line of code, it will run a search on the main window whenever you close that form, even if that does not include the "My InBasket" grid. You'd have to implement some checks in the code beforehand for that.
Hope this helps,C
Hi cogres, thanks for the answer!
I've applied the code, but when the form is unloaded this error occur:
Event handler failed with message: TypeError: aras.getMainWindow(...).work is undefined [function onbeforeunload$user$handler(e) { try { if (onbeforeunload1(e) === false) return false; } catch (exp) { aras.AlertError(aras.getResource('', 'ui_methods_ex.event_handler_failed'), aras.getResource('', 'ui_methods_ex.event_handler_failure_msg', exp.description ? exp.description : (exp + ' [' +arguments.callee.toString()+ ']')), aras.getResource('','common.client_side_err')); return false; } }]
Thanks in advance for the help!
Regards,
Jonatas
