I have a property department in parent item type,I would like to hide some columns in relationship grid depends on department property when the form on populated event.
it is possible when that relationshiptype is not added in any other item type's relationshiptype
- tenny7 years agoIdeator III
please tell me how to do that, thanks.
- SivaKumarReddy_P7 years agoIdeator II
Hi tenny,
Hope this is useful.
var inn=new Innovator();
var cType=document.thisItem.getType();var iType=inn.newItem("ItemType","get");
iType.setAttribute("where","[ItemType].name='"+cType+"'");
iType=iType.apply();var RT=inn.newItem("RelationshipType","get");
RT.setAttribute("where","[RelationshipType].source_id='"+iType.getID()+"' and [relationshiptype].name=''");//relationship type name
RT=RT.apply();
var relId=RT.getProperty("related_id");var nProp=inn.newItem("Property","get");
nProp.setAttribute("where","[Property].source_id='"+relid+"' and [property].name='property name'");//say department
nProp=nProp.apply();if(document.thisItem.getProperty("say department")==="")//give your dept name
nProp.setAction("edit");
nProp.setProperty("is_hidden2","1");
else{
nProp.setProperty("is_hidden2","0");
aras.clearClientMetadataCache();
}- angela7 years agoCatalyst II
Hi Siva,
thanks for sharing your sample code! Will it also work when several people work within the same instance in parallel? As you directly change the ItemType property I assume it will work well for a certain amount of people. But what will happen when around 1000 users will move around in the same ItemType?
I am also interested in the use case, but haven´t found a solution yet. But in the past I was thinking about a Method that uses dijit to influences the relationship content. But that was just an idea...
// EDIT: I think made some mistake reading your code. You only overwrite the property settings in the DOM, not in the database, correct? That of course shouldn´t make any trouble. :-)
