Kitty
1 year agoIdeator II
How can I control behavior of BOM on revision up
Hi community,
Here is an use case that User want to control Part by item that make the BOM are float or fixed when revision up.
I read some solution that you can use a customized property and replace the action when creating a new revision.
But I need more explain on doing this.
Thanks to read this.
