Dayanand_Languti's avatar
3 months ago
Failed to compose adapter URI. Processing aborted!
I am getting this error for custom template while updating data. sometime its works also, Please can you help on this.
Appreciate your help!
Thank you!
  • eli_donahue's avatar
    eli_donahue
    Hi, Dayanand_Languti 👋 Can you provide a little more information about this error?
    • Are you using the Office Connector, or another kind of custom template?
    • Do you know if your environment uses a load balancer?
    • Dayanand_Languti's avatar
      Dayanand_Languti
      Thanks for replaying me.
      Sorry to check your message after long time.
      Yes we have load balancer.
      I have created a ARAS method which updates data in one of the item template,
       when i run that function it works but locks some records not all.
      when i open same record (locked one) in item template view and click on update it through
      for not locked data it works fine.
      Thank you.
