eli_donahue
3 months agoCommunity Manager
Hi, Dayanand_Languti 👋 Can you provide a little more information about this error?
- Are you using the Office Connector, or another kind of custom template?
- Do you know if your environment uses a load balancer?
Dayanand_Languti
1 month agoIdeator I
Thanks for replaying me.
Sorry to check your message after long time.
Yes we have load balancer.
I have created a ARAS method which updates data in one of the item template,
when i run that function it works but locks some records not all.
when i open same record (locked one) in item template view and click on update it through
Failed to compose adapter URI. Processing aborted!
for not locked data it works fine.
Thank you.
