Logesh's avatar
Logesh
4 months ago
Import Package Fails with Foreign Key Constraint Error
Hi Team,
I am encountering an issue while importing a package in Aras Innovator. The import fails with a SQL foreign key constraint error related to Item Action.
Error Message
Import package 'com.aras.innovator.solution.PLM' failed with message: The UPDATE statement conflicted with the FOREIGN KEY constraint "FK__ITEM_ACTI__RELAT__002AF460". The conflict occurred in database "OGE_innovator31_RE7", table "innovator.ACTION", column 'ID'. The statement has been terminated. SQL: UPDATE [ITEM_ACTION] SET [RELATED_ID] = @related_id WHERE [ID] = @id
Help me to solve this error.
Thanks
  • Hello Logesh,
    This error indicates that ITEM_ACTION.RELATED_ID is referencing an ACTION that does not exist in the target database.
    To resolve the issue, please check the following:
    • Verify that the referenced Action exists
    • Ensure the related_id (Action) is included in your package.
      -> (do you have the Folder "Action" and the xml inside in the "Import" Folder?)
    If not, re-export the package including Actions (with dependencies).
    Compare IDs
    • Check if the related_id points to an ID that does not exist in the target system.
    • This can happen between environments (for example, when a versionable item is updated and the ID changed — I’ve personally missed updating it in one of the files before).
    Review package completeness
    • Make sure you didn’t export only part of the configuration (e.g., ItemType without its Actions).
    In my experience, this is the most common cause of this error.
    Michael
