9 years agoAccelerator III
Error while creating a Project from ARAS.IOM api
I am trying to create a Project using Aras.IOM API. I have given all the mandatory fields values, like target start date, target finish date, project name etc.... but still error is thrown:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="">schemas.xmlsoap.org/.../" xmlns:i18n="">www.aras.com/I18N"><SOAP-ENV:Body><SOAP-ENV:Fault><SOAP-ENV:Envelope xmlns:SOAP-ENV="">schemas.xmlsoap.org/.../" xmlns:i18n="">www.aras.com/I18N"><SOAP-ENV:Body><SOAP-ENV:Fault> <faultcode>1</faultcode> <faultactor></faultactor> <faultstring>Method server_update_schedule failed: FAILURE: WBS_ID is null</faultstring></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
Am I missing some file values?? Looks like WBS_ID is null but what should be its default value?
