Nathan_H_'s avatar
Nathan_H_
Accelerator I
ECO Validation
Good day all.  I am trying to set up a validation (C#) for a field to make sure it is completed before moving to the next step in the Workflow Process.  I have seen some information for validating a checkbox in C# and some form of validation with VB (I don't know VB).  I can't seem to get this to work.  The coding I have tried either stop everything or don't stop anything.  I added the method to the Workflow Map Path as a Pre Method.  I would appreciate any help with identifying what I have missed.  Thank you.
Change Request - sm_DEMO_NDR (it is a testing ground for me)
Property - sm_change_end_state
Item controlledItem = this.apply("s_Get Controlled Item");
string is_completed = controlledItem.getProperty("sm_change_end_state");
if (is_completed =="") return inn.newError("Must be complete!");
return this;
// Set up the query Item.
Item qryItem = this.newItem("sm_DEMO_NDR","get");
qryItem.setAttribute("select","sm_change_end_state");
//qryItem.setID(endState);
if (qryItem = "") return inn.newError("Please select appropriate End State.");
return this;
Item endState = this.newItem("sm_DEMO_NDR","get");
string state = endState.getProperty("select","sm_change_end_state");
if (this.endState == "") {return inn.newError("Please select appropriate End State.");};
  • Seems like you have assigned an id to get a controlled item. This is my variant based on an original Aras sample:
    // Get the controlled item.
    Item controlledItem = this.newItem(this.getAttribute("type"), "labs_GetControlledItemCSharp");
    controlledItem.setID(this.getID());
    controlledItem = controlledItem.apply();
    if (controlledItem.getItemCount() != 1)
    return inn.newError("Error retrieving the controlled item: " + controlledItem.getErrorDetail());
    string teamId = controlledItem.getProperty("team_id","");
    • Nathan_H_'s avatar
      Nathan_H_
      Accelerator I
      Angelalp,
      Thank you for this.  I got it working.  I added the method to the Activity as a Server Event that activates On Vote.
      //Get what is selected for sm_change_end_state
      string endState = controlledItem.getProperty("sm_change_end_state","");
      //If sm_change_end_state is empty, return the message.
      if (endState == "") return inn.newError("Please select appropriate End State.");
      return this;
