Shekhar's avatar
Shekhar
Disabling a field of type Text Area
Hello Experts,
I need to disable a field of type Text Area. I am using the below code on form populate event
var input1 = getFieldByName("Test_Text_Area");
setTimeout(function() {
input1 .getElementsByTagName("input")[0].disabled = true;
}, 100);
When the field is of type Text, the above code works fine but when its of type Text Area , the field is not getting disabled.
Any help is highly appreciated.
Regards,
Shekhar
  • Hi Shekhar,
    getElementsByTagName("input") only works for regular fields.
    Try getElementsByTagName('textarea'). I am not sure if this will work together with getFieldByName. Maybe you can also directly call your textarea:
     var input1 = document.getElementsByTagName('textarea')[0];
    Haven´t tested the samples, but I hope one of them works.
    Ciao,
  • Hi Shekhar,
    Ciao,
    • Shekhar's avatar
      Shekhar
      Thanks a lot for the quick help Angela. The solution
      input1.getElementsByTagName("textarea")[0].disabled = true;
      worked.
      Regards,
      Shekhar
