Shekhar
7 years agoIdeator III
Disabling a field of type Text Area
Hello Experts,
I need to disable a field of type Text Area. I am using the below code on form populate event
var input1 = getFieldByName("Test_Text_Area"); setTimeout(function() { input1 .getE...
- 7 years ago
Hi Shekhar,
getElementsByTagName("input") only works for regular fields.
Try getElementsByTagName('textarea'). I am not sure if this will work together with getFieldByName. Maybe you can also directly call your textarea:
var input1 = document.getElementsByTagName('textarea')[0];
Haven´t tested the samples, but I hope one of them works.
Ciao,
