Shekhar's avatar
Shekhar
Disabling a field of type Text Area
Hello Experts, I need to disable a field of type Text Area. I am using the below code on form populate event var input1 = getFieldByName("Test_Text_Area"); setTimeout(function() { input1 .getE...
    Hi Shekhar,
    getElementsByTagName("input") only works for regular fields.
    Try getElementsByTagName('textarea'). I am not sure if this will work together with getFieldByName. Maybe you can also directly call your textarea:
     var input1 = document.getElementsByTagName('textarea')[0];
    Haven´t tested the samples, but I hope one of them works.
    Ciao,
