9 years agoAccelerator III
Disabeling dropdown field on form
Hi
I have some strange behaviour on a form. I have added a JaveScript method to disable some fields if the property "kam_is_transferred" = 1. The strange thing is the code below works on text fields but it doesn't seem to work on dropdown fields. Is the procedure different for drop down fields?
//Set Part form item_number field properties based on kam_is_transferred field value.
// Called onLoad from Part Add and Part Default forms.
// Sets form properties.
var thisItem = document.thisItem;
var istransferred = thisItem.getProperty("kam_is_transferred");
var itemnumber= document.fieldsTab["item_number"].substring(0, 32);
var name= document.fieldsTab["name"].substring(0, 32);
var kam_ksup= document.fieldsTab["kam_ksup"].substring(0, 32);
//disables enables Part Number field based on checkbox.
//kam_is_transferred = 1
if (istransferred=="1"){
document.getElementById(itemnumber).disabled= true;
document.getElementById(name).disabled= true;
document.getElementById(kam_ksup).disabled= true;
// IR-041257 - 04/20/2016
var cbc = parent.dijit.byId("CenterBorderContainer");
cbc.layout();
// end of fix
Thanks in advance
Henrik Olesen
Kamstrup A/S
Denmark
