8 years agoCommunity Manager
Hi Ben,
In 11.0 SP12+, dropdowns have been replaced by an input field and a button in order to support type-ahead as you've said.
You can disable dropdowns in these newer service in a very similar way to the sample of code that Jill initially gave. Please see the example below which you can use in SP12+.
// get the form field "container"
var wrapper = getFieldByName("field_name");
// disable the text input of the dropdown
wrapper.getElementsByTagName("input")[0].disabled = true;
// disable the button that brings up the list of options for the dropdown
wrapper.getElementsByTagName("button")[0].disabled = true;
