miraks's avatar
miraks
Customize login panel
On the login panel, I would like to add a button or a link to an external form to request an account.
Something like this:
Is it possible to do that in ARAS R12 SP8 ?
Thank you in advance.
Regards.
  • Hi Mirkas!
    the answer is yes and no! The start page cannot be modified cause it´s generated on run time and the code is not accessible. Aras does not give us the possibility to modify this page. But you can manipulate the start page during form load:
    Take a look at the comments of this blog article: https://community.aras.com/b/english/posts/modifying-ui-elements
    • miraks's avatar
      miraks
      Hi Angelalp,
      Thank you for your answer.
      I can see in the blog article that you find a solution but you said that "I don´t want to share my current solution in public right now, cause I want Aras to provide a better solution.".
      Could you share your solution with me in private ?
      For your information, I tried to add a button into the SVG opening a specific html page but this doesn't work because the SVG is added in the page through a:
      style="background-image: url("">fr0-viaas-101/.../arasInnovator.svg");"
        I share the solution to community members that can explain credibly that they solely want to use it for their own Innovator instance and don´t sell it to other customers.
        I don't want to support community members who steal ideas from the forum for their own businesses without ever contributing anything.
        @Miraks: As I see that you actively help people in this forum, you have a good change :-)
