thofste
8 years agoIdeator I
Hello Zahar,
Thank you for your suggestion.
I wasn't able to get the user information on the id, so I did it the long way and that seems to work.
I also needed to extend the method with a if statement so when the {prop2} is empty.
Item identItm =this.getPropertyItem("related_id");
string userId = this.getProperty("source_id");
Item userItem = this.newItem("User","get");
userItem.setProperty("id",userId);
userItem = userItem.apply();
Item updateIdnt = this.getInnovator().newItem("Identity", "merge");
updateIdnt.setID(identItm.getID());
if (userItem.getProperty("{prop2}","") == null)
updateIdnt.setProperty("name", userItem.getProperty("{prop1}", "") + " " + userItem.getProperty("{prop3}",""));
} else
updateIdnt.setProperty("name", userItem.getProperty("{prop1}", "") + " " + userItem.getProperty("{prop2}","") + " " + userItem.getProperty("{prop3}",""));
updateIdnt.apply();
return inn.newResult("");
