6 years agoCatalyst II
Change style of default Form button (without using a full custom html button)
Hi community,
has anybody some experience with customizing the standard blue form buttons in Innovator?
I want to make them
not blue
fixed size independent from button label
round corners...
- 6 years ago
Hi Angela,
I have used the following before, so maybe it will help you, too.
The background colour can simply be picked under the "Field Type" tab when editing the form:
Under the "Form Body" tab, you can then insert some CSS for input elements that are buttons:
Then button then looks like this:
The "border-radius" makes the corners round, since that was one of your requirements.
Hope this helps,
C
