jeff_stroh's avatar
jeff_stroh
Button not adhering to CSS
I've got a button with very simple CSS (below).  Problem is, the button isn't adhering to the code:
{$this field rule} input;
input[type="button"]{
height: 50px;
width: 50px;
input[type="button"]:disabled{
background: #dddddd;
On both the form editor and the form in use, it's not following the dimensions
Form Editor - not square
On Form when viewing ItemType
The button activates a method which is working as expected, so my only issue is the size of the button isn't doing what I want.
As an alternate, I tried using an HTML field with my code to run a script, but the script doesn't seem to work on "onclick" for the HTML field; though the HTML formatting shows up as expected.
Code below:
<html>
<body>
<input type='button'
onClick="function(VHVL)"
style="height:40px;
width:40px;
background-color: RGBA(255, 255, 0);
border: 1px solid RGBA(128, 128, 128, 0.5);
padding: 0.25em;">
<script>
function (VHVL) {
// Create an Innovator object
var myInnov = new Innovator();
var riskprobability = "1";
var riskimpact = "1";
var probabilityDropdown = getFieldComponentByName('_riskprobability');
probabilityDropdown.component.setState({value: riskprobability});
window.handleItemChange("_riskprobability", riskprobability);
var impactDropdown = getFieldComponentByName('_riskimpact');
impactDropdown.component.setState({value: riskimpact});
window.handleItemChange("_riskimpact", riskimpact);
var SeverityScore = riskprobability * riskimpact
window.handleItemChange("_riskseverityscore", SeverityScore)
if (riskimpact >= 4 && riskprobability <= 2) {
window.handleItemChange("_riskhilp", "1");
else
window.handleItemChange("_riskhilp", "0");
if (SeverityScore > 4) {
window.handleItemChange("_riskromap", "1");
else
window.handleItemChange("_riskromap", "0");
</script>
</body>
</html>
I don't really care whether I do this as a button or as an HTML field, but I do need the "item" to look right and execute the code.  Appreciate any help on this!
  • Regarding Aras buttons:
    Which tab do you use to do your styling? Field CSS or Form CSS?
    1. Your first code works in 'Form CSS' (overall Form styling) when you remove {$this field rule} input; .
    2. Your first code works in 'Field CSS' (individual element styling) when you remove input[type="button"] ;
    Regarding html buttons.
    Your button html code contains multiple errors. Your function call is creative (but wrong :-) ) and you mix ' with ". Compare with this one:
    <input type="button"
      onClick="myfunction();"
      style="height:40px;cursor:pointer;width:40px;"
    <script>
    function myfunction() {
      alert("x");
    </script>
    Instead of using tons of buttons, I personally would use a html table for this use case. Harder to design, but a lot easier to maintain. Of course a matter of taste.[emoticon:c28b2e4cc20f4ba28d1befdba6bed29c]
    <script>
      alert("x");
    </script>
    • jeff_stroh's avatar
      jeff_stroh
      Thank you!  I got it working with an HTML table and got color changes on click like I wanted.  Now just need to take the dropdown events and have them update/select the right cells in the HTML table.
      Appreciate it!
