Morgan's avatar
Morgan
Creator III
4 years ago
Affected Items Floating relationship not floating on Express ECO
Hi all,
Strange error happening here. For some unknown reason, when an item is on an ECO and it is versioned, the relationship is not floating to latest. In my dev environment it is working fine and the other environment is just a push from the dev environment. I tried resetting the behavior and still nothing.
I've had this issue before and I was able to resolve it by deleting the relationship and reimporting however that was a relationship I had created and in this case the OOB relationship has so much going on that I'd rather not.
Any suggestions?
  • Which relationship did you modify? The floating behavior in ECOs is influenced by many factors. Here a random collection:
    - Part lifecycle
    - BOM RelationshipType behavior setting
    - PE_AffectedItemFloat Method in Part
    - PE_ChangeItemFloatNewItem in Affected Item
    • Morgan's avatar
      Morgan
      Creator III
      Thanks for the reply! I actually ended up rebuilding the database to solve the issue.
