cambrianexplosion
6 years agoIdeator II
Uploading a local file to Innovator using the Batch Loader
I'm having issues uploading a local file to an instance of Innovator using the Batch Loader. I have the following XML:
<Item type="Document File" action="add">
<related_id>
<Item type="File" action="add">
<actual_filename>C:\some\file\path\@1</actual_filename>
<filename>@1</filename>
</Item>
This currently fails. I had to search to find out the <actual_filename> tag is used for the fully qualified path of the file, yet it is not present in the File Item when inspecting it through Innovator Client.
Any help with this would be appreciated.
