cambrianexplosion
6 years agoIdeator II
I've realized now that I need to specify a relationship to a vault and have changed the AML to the following:
<Item type="Document File" action="add">
<related_id>
<Item type="File" action="add">
<actual_filename>C:\some\file\path\@1</actual_filename>
<filename>@1</filename><Relationships><Item type="Located" action="add"><related_id>67BBB9204FE84A8981ED8313049BA06C</related_id></Item></Relationships> </Item>
However now I am greeted with a "File does not exists" exception even though the file does exist at the fully qualified path specified by <actual_filename> tag
