Hi Mikael
You can use below piece of code to achieve this.
Step 1: Open Workflow of ECO
Step 2: Click on path "Fast Track Approve"
Step 3: Add below method as Pre Methods event
//Method Type : Server Side (C#)
Innovator inn = getInnovator();
//Allowed Identities (CM and Adminstrators Identity ID)
string allowedIdentity = "F6624E9AE5504958A84E4B6A5831298B,2618D6F5A90949BAA7E920D1B04C7EE1";
string path = this.getProperty("name");
string userID = inn.getUserID();
Item alias = inn.newItem("Alias", "get");
alias.setProperty("source_id", userID);
alias.setAttribute("select", "related_id(id)");
alias = alias.apply();
if (alias.isError()) {
return alias;
string aliasId = alias.getProperty("related_id");
string whereCondition = "[Member].related_id=\'" + aliasId + "\'";
Item IdentityCheck = inn.newItem("Member", "get");
IdentityCheck.setAttribute("where", whereCondition);
IdentityCheck.setAttribute("select", "id");
IdentityCheck.setProperty("source_id", allowedIdentity);
IdentityCheck.setPropertyCondition("source_id", "in");
IdentityCheck = IdentityCheck.apply();
if (IdentityCheck.isError()) {
return inn.newError("Only Members of CM and Administrators Identity can select this Path. Please reselect the Path");
return this;
Thank You
Gopikrishnan R
Thanks Gopikrishnan, I will test it
//Mikael
