smruti_barik's avatar
smruti_barik
Ideator II
Requirement Engineering in Aras 11Sp12
I am trying to install Requirements engineering with Aras 11Sp12 . It failed and threw error that it is not compatible with this version of innovator.
What is the correct version of Innovator to use Requirement Engineering ?
  • Hello,
    I think the problem is that the Item Type tp_Applications doesn't exist yet. You can create it like this:
    TOC -> List -> New Item -> tp_Applictions (ID Item)
    You should download REQ11R1 and read file RE\11.0.222\Imports\RE\Import\Fixes\tp_Applications.xml.
    You edit file tp_Applications, replace id >> ID Item in line below:
     <Item type="List" id="4D54789248344C9AAC2E88A47CD93158" action="edit">
    <source_id keyed_name="tp_Applications" type="List">4D54789248344C9AAC2E88A47CD93158</source_id>
    Then, you will manual install Import Tool.
    Good luck,
    Henry Tu
    • rif6894's avatar
      rif6894
      Henry
      Can you please confirm the release(s) of the ARAS product and the Requirements Engineering module?
      Did you try installing Requirements Management 6 under ARAS 11R14?
      Thanks in advance
  • Hello,
    You'll need to use Aras Innovator 11.0 SP15 in order to install Requirements Engineering 11.0 R1.
    Requirements Engineering is a new application that was built to replace the existing Requirements Management application that was supported in older versions including 11.0 SP12.
    • Henry_Tu's avatar
      Henry_Tu
      Hello Chris,
      I have successfully installed Requirements Engineering 11.0 R1. But I encountered another problem, Editor Interface is completely pure white. Picture attached below.
      Please to help me.
      Thanks,
      Henry Tu
