Henry_Tu
7 years agoIdeator III
I think the problem is that the Item Type tp_Applications doesn't exist yet. You can create it like this:
TOC -> List -> New Item -> tp_Applictions (ID Item)
You should download REQ11R1 and read file RE\11.0.222\Imports\RE\Import\Fixes\tp_Applications.xml.
You edit file tp_Applications, replace id >> ID Item in line below:
<Item type="List" id="4D54789248344C9AAC2E88A47CD93158" action="edit">
<source_id keyed_name="tp_Applications" type="List">4D54789248344C9AAC2E88A47CD93158</source_id>
Then, you will manual install Import Tool.
Good luck,
Henry Tu
- rif68947 years agoCreator I
Henry
Can you please confirm the release(s) of the ARAS product and the Requirements Engineering module?
Did you try installing Requirements Management 6 under ARAS 11R14?Thanks in advance
