H_Sakamoto_HTC's avatar
H_Sakamoto_HTC
Ideator II
1 year ago
Installing Aras Innovator and SQL?
I have a question about installing Aras Innovator and setting up the environment. When I checked the installation guide, there was no mention of SQL Server during installation. Please tell me what I should do before installation and what I should do after installation. I believe that Aras Innovator indirectly manipulates SQL.
There was a mention of SQL during installation in the Japanese blog.
Reference URL
aras.com/.../install-2023-release
  • ichiro-mizoguchi's avatar
    ichiro-mizoguchi
    1 year ago
    Hello Mr. Sakamoto,
    When I became an Aras user in the spring of 2018, I remember there was a forum where users could communicate directly in Japanese.
    (However, since no one posted there, it quietly disappeared.)
    I believe this forum might support non-Latin characters, so I'm writing this post as a small experiment.
    Best regards,
    Ichiro Mizoguchi
    P.S.
    Recently, translation accuracy has improved significantly.
    So I’ve started using Google Translate for rough drafts,
    and then asking Copilot to refine them by checking things like:
    “Is this an appropriate question?”
    or
    “Is this an appropriate answer?”
    こんにちは。サカモトさん
    私がArasユーザーになった2018年の春には、確か日本語で直接やり取りできるForumというものが存在していました。
    (が、誰も書き込まないのでいつの間にか消滅していました)
    多分、このForumで2バイト文字が扱えるのでは、という気がするので、実験的に書いてみますね。
    溝口一郎
    蛇足
    最近は翻訳の精度が上がっていますので、
    Google翻訳で適当に翻訳させてから、
    「質問文として適切になっているか」
    とか
    「回答文として適切になっているか」
    という感じで、Copilotに添削させればよいのでは、と自分は考えるようにしています。
  • Hello Sakamoto-san,
    Regarding your question, based on my understanding and the documentation, here is what I think you should do:
    **Before installation:**
    - Please install SQL Server in advance.
    - Set a password for the 'sa' account and make sure you can connect to the server using SSMS.
    **After installation:**
    - If you are not using the Express Edition, I recommend setting up SQL Server Agent to perform daily backups automatically, after confirming that Aras Innovator is working correctly.
    I hope this helps.
    Best regards,
    Ichiro Mizoguchi
    • H_Sakamoto_HTC's avatar
      H_Sakamoto_HTC
      Ideator II
      MMizoguchi-san
      Thank you for your message.
      First, I will refer to the blog and advice.
      This site was introduced to me by a business partner. If possible, could you let me know if this site is available in Japanese?
        ichiro-mizoguchi
        Hello Mr. Sakamoto,
        Best regards,
        Ichiro Mizoguchi
        P.S.
        or
        こんにちは。サカモトさん
        溝口一郎
        蛇足
        最近は翻訳の精度が上がっていますので、
        「質問文として適切になっているか」
        とか
        「回答文として適切になっているか」
