North's avatar
North
Can't do a bulk ALM code input.
Hello, not sure if anyone is having this problem but I seem to not be able to do a bulk item creation with AML.
I'm using Nash which has worked before but when I put this code in for example:
<AML>
<Item type='Part' action='add'>
  <item_number>234-17351-0001</item_number>
    <description>A test assembly</description>
</Item>
  <item_number>131-87171-0001</item_number>
    <description>Another test assembly</description>
</Item>
</AML>
All that gets added is the first part number and the second number is never created. Is there something I am missing from my code?
  • Hi North
    I believe the issue is because the action in nash is set to applyItem instead of applyAML.
    In Nash, ensure that Action: = applyAML instead of applyItem
    Thank You
    Gopikrishnan R
    • North's avatar
      North
      Hey Gopikrishnan,
      It is currently in the ApplyAML and I am still getting the same problem.
      • Gopikrishnan's avatar
        Gopikrishnan
        Hi North
        I used the same AML and able to create two parts. Try with different item_numbers or try create two documents. If one part is created, are you getting any error in AML output ?
        Thank You
        Gopikrishnan R
