Gopikrishnan
6 years agoAccelerator II
Hi North
I believe the issue is because the action in nash is set to applyItem instead of applyAML.
In Nash, ensure that Action: = applyAML instead of applyItem
Thank You
Gopikrishnan R
North
6 years agoIdeator II
Hey Gopikrishnan,
It is currently in the ApplyAML and I am still getting the same problem.
- Gopikrishnan6 years agoAccelerator II
Hi North
I used the same AML and able to create two parts. Try with different item_numbers or try create two documents. If one part is created, are you getting any error in AML output ?
Thank You
Gopikrishnan R
- North6 years agoIdeator II
Thank you Gopikrishnan for your help, it seems to be working now. Aras seems to not want to ApplyAML when a part is already there.
Glad to hear.
