9 years ago
Timestamp error after applying 11.0 SP10 patch
Looking for some help. I was following along with the instructions in the "Upgrade from Version 11.0 SP8 to Version 11.0 SP10" directions, and I got to the point where you copy the contents of the .zip over tot he innovator and vault folder, re-set IIS portion and I have run into an issue.   The application will no longer display a login, and any attempt to login to a db shown by the the "aras innovator solutionupgrade" (import.exe),  I am met with this error:   Login errors ****ErrorMessage**** faultstring: Failed login to Innovator; original error: SOAP-ENV:ServerThe type initializer for 'Aras.I18NUtils.TimeZoneInformation' threw an exception.The type initializer for 'Aras.I18NUtils.TimeZoneInformation' threw an exception. faultdetail:Failed login to Innovator; original error: SOAP-ENV:ServerThe type initializer for 'Aras.I18NUtils.TimeZoneInformation' threw an exception.The type initializer for 'Aras.I18NUtils.TimeZoneInformation' threw an exception. Unable to login. faultcode: -100 *******************     Any tips on what setting I should be looking to change? There was something about changing the time zone settings inside the aras application, but since it won't launch...
  • Figured this one out.   Turns out the version of .net was way behind for this SP level.
  • Thanks for coming back with the reason of the trouble ! Lesson's learned "always check the .net Requirements !" (which is not always easy to do ! :) )
