Selva's avatar
Selva
2 months ago
virtualGetForm 404 when accessing Aras through Nginx
I’m running Aras Innovator 14.35.0.44037 behind an Nginx reverse proxy.
Setup:
Client ↓ HTTPS Nginx ↓ HTTPS :15018 Aras Innovator
External URL:
https://aras.veconnected.in/VECS_ARAS/
Nginx:
location /VECS_ARAS/ { proxy_pass https://127.0.0.1:15018/VECS_ARAS/; proxy_ssl_verify off; proxy_http_version 1.1; proxy_set_header Host $http_host; proxy_set_header X-Forwarded-Proto https; proxy_set_header X-Forwarded-Host $http_host; proxy_set_header X-Forwarded-Prefix /VECS_ARAS; proxy_buffering off; proxy_request_buffering off; }
Most Aras Client requests work correctly through Nginx and return:
status=200 upstream_status=200
However, when opening Item Forms, the following request returns 404:
GET /VECS_ARAS/Client/X-salt=3_14.35.0.44037-X/scripts/virtualGetForm? formId=47B8630E2B4C40C1B23C6EE9962F7681& formLastModifiedDate=2025-05-29T19:48:04.24& languageCode=en& itemTypeId=450906E86E304F55A34B3C0D65C097EA& itemTypeLastModifiedDate=2025-05-29T19:44:47.74& databasehash=3a52875cf3d26f02& mode=add
Chrome reports:
404 (Not Found)
In some cases DevTools reports:
404 (Not Found) (from service worker)
Important observations:
  • The same form works when accessed directly from a browser on the Aras VM.
  • Other X-salt resources work correctly through Nginx.
  • Metadata requests and InnovatorServer.aspx requests return 200.
  • I cannot find the virtualGetForm request in the Nginx access log when the client gets the 404.
  • Aras service-worker.js is registered and being served.
  • The problem occurs with multiple forms.
Could virtualGetForm be intercepted by the Aras service worker/cache and returning a cached 404?
Is there a recommended way in Aras 14.35 to invalidate/reset the client service-worker/cache, or any known Nginx configuration requirements specifically for virtualGetForm?
