Revisions/Item Versions appearing blank
Hi all, Created a new ItemType. Initially, when viewing an instance, Views > Revisions displays the Item Versions. However, after creating a few items, it then appears blank, as illustrated here: I haven't changed anything (as far as I know), it just stops rendering after some time. Any input would be greatly appreciated. Aras Version 11 SP9. Thanks very much.142Views0likes5CommentsRevision List Pop-Up Box Too Small
Hello, I've created an item type that is versionable. When viewing the revisions list on the item, however, the pop-up box that appears is very small and you need to scroll horizontally to view all the fields. Is there a way to make it bigger? Version 11 SP9 Thanks!111Views0likes3CommentsBrowse the versions of an item
Hi everyone , I'm currently trying to implement a C# method that should be able to browse all the versions of a Part Item , thus we can read the states of the different versions and promote them . but the problem is that I don't know how to get the versions of an Item . Does anyone know how to solve this issue please ? Thanks in Advance Hamdi5.6KViews0likes4CommentsHow to stop\pause life cycle promotion to edit a part?
I need to edit some Part properties such as State, Release Date, Revs, etc. But everytime a Part is edited a new version is created where the Rev increments. I do not want this to happen. I want to edit the part and have it not create a new version.Solved116Views0likes2CommentsWarning: Versioning and tab pane very buggy in new Innovator versions!!! Are you affected?
Hi community, I need your help to investigate an error that occurs in newer Innovator versions. In my case it occurred in Innovator 12SP17 and 12SP18 but NOT in Innovator 12SP7 / 9 / 10. I look for a bug fix for this one, cause unfortunately Aras rate this one as unimportant glitch and not as high risk behavior. From my POV the bug is a huge source for trouble (data loss!!), so I just can warn people to update to SP17 and SP18 without this bug fixed. I want to investigate, which service pack version is NOT affected by this bug. I am not able to test out all available service pack, so I would be happy if community could help: If you are a user of Innovator 12 SP11 / 12 / 14 / 15 / 16 / 17 I would be happy if you could test out at least the Error 1 scenario!! (2 minutes required!) Scope In 12SP17 and 12SP18 the tab pane can crash to easily when using item versions (like in Parts, Documents and Methods). In addition, old item revision can overwrite the latest item without the user noticing it! Both errors can occur easily, as soon users display previous revisions of an item. Comparing old and new revisions is a typical work during a Change Management process, so it´s an error that affects daily work of PLM users. Test Setup If possible perform this test in a test database. No data is edited during the test when you closely follow the instructions. But I don´t want to bring you in trouble in case of error! 1. Go to TOC -> Administration -> Open ItemType "Method" search grid 2. Search for Method with with "Ver 2" or higher, to ensure the Method has more than one revision. (If you need extra safety, create a temporary custom Method for this test that you can delete after test finished) 3. Open this Method (it doesn´t matter which one) 4. Open the 'Versions' dialog 5. Select a previous version (e.g Ver 1) of this Method 6. A Form with the previous version of your Method shall open. 7. Do not touch the new window with the previous version 8. Simply switch back to the tab with the newest version of the Method and close the "Versions" dialog We now have both versions in parallel in the tab pane. This is our basic setup. So far everything is fine. Reproduce Error 1 (Tab pane crash) 1. Start from setup above. We are in the tab with the latest revision 2. Click "Edit" (but do nothing else)! 3. Now just switch back to the tab with the previous revision of the Method and simply close this window 4. After closing the previous revision, we will automatically jump back to our latest revision tab 5. Click "Discard" as we never wanted to edit anything 6. Now the error should happen: In case of error a second tab reappears. We now have the two tabs for the item. They do not work and you cannot close them. Tab pane is crashed. Everything will be fine again after restarting Innovator in browser. If you don´t see this error, your Innovator version is not affected by this bug. You can skip all other tests. Please share which version you used! Reproduce Error 2 (glitch) 6. When you directly click "Search Method" in the TOC after above error occurred, a small additional glitch can appear 7. As our tab pane is crashed, the search grid will overlab with the Method Form. None of the tabs can be used reliable anymore Reproduce Error 3 (previous revision overwrites latest) Warning: Perform only in test database! Use a custom temporary Method for testing out this one, cause it can corrupt your data!!! 1. Start from setup above. We are in the tab with the latest revision. 2. First switch back to the tab with the previous revision. This time do not close the window, but simply take a look at the "Edit" button. It´s grayed out and you cannot use it. (This is correct behavior, as we never should be able to edit previous revisions) 3. Switch back to the latest revision and click "Edit" 4. Again switch back to the previous revision and take a look at the "Edit" button again. This time it´s not greyed out anymore!!! 5. It´s now theoretically possible to click the edit button inside the Form of the previous revision! 6. In case you click the 'Edit' button, you can create a high risk scenario: 7. After clicking the 'Edit' button, it´s seems to be possible to edit the previous revision. But what you see doesn´t represent the "truth" any more. a) The shown Method code still shows the content of the previous revision b) But the context item has switched to the latest revision. But this revision change is not visible to users as they still watch the previous code/properties. You can only see it in the 'Generation' value in the 'Properties' dialog. If you now save your "fake" previous item, the latest item will be overwritten with code and properties of the previous version. This is a high danger situation not only for Methods, but for all ItemTypes that use revision as it will lead to data loss and corrupted data. Conclusion I discovered the bug while merging a few upgrade patches and actually destroyed a few Methods cause of this bug. If I as admin fail to handle versioned items cause of this behavior, I expect that real users will face the same problem soon. I right would not recommend to use 12SP17/18 just because of this bug. Comparing and working with item versions is a daily task especially when using Change Management. But it´s important that users can trust the data they see. Right now working with revision in SP18 is very risky cause users can crash their tab (best case) or overwrite data without knowing (worst case). Please let me know if you are able to reproduce any of the above bugs in your Aras Innovator version! If you´re Innovator version doesn´t show the bugs, please also write a short post! When we can determine in which service pack the error appeared first, it´s maybe possible detect the bug more easily. Thanks for your help! Angela11KViews0likes15CommentsThe item gets closed on new generation/version on lifecycle
Whenever I create a new generation/version using csharp code on lifecycle it would always close the item, is there any function i can use which does not close it? below is my code Aras.Server.Security.Identity plmIdentity = Aras.Server.Security.Identity.GetByName("Aras PLM"); bool PermissionWasSet = Aras.Server.Security.Permissions.GrantIdentity(plmIdentity); Innovator inn = this.getInnovator(); try { Item myThis = this.apply("version"); } catch (Exception e) { return inn.newError(e.Message); } return this;3.5KViews0likes7CommentsUpload File without creating a new generation
I wish to create an Action for the Document ItemType that 1. Prompts the user to select a file, 2. Uploads the file, and 3. Does not create a new generation of the Document Item. Use Case: A Document, for example at Rev C, are reviewed via the out-of-the-box (OOTB) Document Change Object. Prior to the Release step, a PDF file is generated and submitted to the customer. The workflow is then completed, setting the state of the Document as Released. The PDF is sent to the customer for approval. And a new revision, Rev D, of the Document is started using subsequent DCO. Not a problem. The customer returns a wet-ink or digital signed PDF file of the Rev C of the Document. This version of the PDF is to be included in the the latest generation of Rev C, which most probably will have been updated by Rev D and subsequent generations. It is not appropriate to add the signed PDF to Rev D or later iteration. This process is possible using AML, by 1. Determine the ID of the latest generation of Rev C of the document. 2. Using admin, drag and drop the file into the file vault. 3. Get the ID of the file, after it has been uploaded, and 4. Using AML <AML> <Item type='Document File' action='add'> <source_id>id of the document at the correct generation</source_id> <related_id>id of the uploaded file </related_id> </Item> </AML> Can the above sequence be done using an Action, a Form with a File Item field or some other method?6.5KViews0likes6CommentsRevert to previous Revision
I have a part which was in released state and revision A. After making some changes, it has moved to revision B and preliminary state. The assemblies related to the part show revision A. I want to revert the part to revision A with released state so that when I click on Views-->where used, I can see all the assemblies related to it. Thanks, Barnali8.5KViews0likes6Comments
