Error loading Recipient Relationship tab of DCO and EDR change management giving error when refreshing the CM tab
Hi, when opening ECO/EDR the first time there is no Proplem opening the Recipients Relationship tap, but when opening another a second ECO/EDR the recipients Relationship tap doesnt load. when trying to refresh the item it gives an error message 'The method "cui_ivicb_refresh_click" failed.' only when changing to another relationship tap i can click on refresh with no error, then if changed back to Recipients the recipients list will appear. this issue was not there before the updates were done on .NET code. please help me if you have an idea about this problem and how to approach it. thanks98Views0likes1CommentTrouble Exporting HTML Table to Excel in Aras Innovator Custom Button
Hello everyone, I've been working on a custom button within the search tab for parts in Aras Innovator. The goal is to export a list of specific parts and their properties through a query and display them in an HTML table. Here's a snippet of the code I'm using to convert the HTML table to Excel and download the Excel file: [embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:4ac1465e-c931-489c-a19e-bb242bc1c5f6:type=javascript&text=var%20htmlCode%20%3D%60%0A%3Chtml%3E%0A%3Chead%3E%0A%3Cmeta%20http-equiv%3D%27Content-Type%27%20content%3D%27text%2Fhtml%3B%20charset%3Dutf-8%27%20%2F%3E%0A%3Cscript%20src%3D%27https%3A%2F%2Fcdnjs.cloudflare.com%2Fajax%2Flibs%2Fxlsx%2F0.16.9%2Fxlsx.full.min.js%27%3E%3C%2Fscript%3E%0A%3Cscript%20src%3D%27https%3A%2F%2Fcdnjs.cloudflare.com%2Fajax%2Flibs%2FFileSaver.js%2F2.0.5%2FFileSaver.min.js%27%3E%3C%2Fscript%3E%0A%3Cscript%3E%0Afunction%20substituteTableToExcel%28%29%7B%0Avar%20table%20%3D%20document.getElementById%28%27all_Parts_AML%27%29%3B%0Avar%20sheet_name%20%3D%20%27ALL_Parts_AML%27%3B%0Avar%20workbook%20%3D%20XLSX.utils.table_to_book%28table%2C%20%7Bsheet%3A%20sheet_name%2C%20cellStyles%3A%20true%7D%29%3B%0Avar%20wbout%20%3D%20XLSX.write%28workbook%2C%20%7B%20bookType%3A%20%27xlsx%27%2C%20bookSST%3A%20true%2C%20type%3A%20%27array%27%2C%20cellStyles%3A%20true%20%7D%29%3B%0AsaveAs%28new%20Blob%28%5Bwbout%5D%2C%20%7B%20type%3A%20%27application%2Foctet-stream%27%20%7D%29%2C%20%27ALL_Parts_AML.xlsx%27%29%3B%0A%7D%0Adocument.addEventListener%28%27DOMContentLoaded%27%2C%20function%28%29%20%7B%0AsubstituteTableToExcel%28%29%3B%0A%7D%29%3B%0A%3C%2Fscript%3E%0A%3Clink%20rel%3D%27stylesheet%27%20type%3D%27text%2Fcss%27%20href%3D%27styles.css%27%3E%0A%3C%2Fhead%3E%0A%3Cbody%3E%0A%24%7BexcelTable%7D%0A%3C%2Fbody%3E%0A%3C%2Fhtml%3E%60%3B] return htmlCode; I'm encountering issues with the export functionality. When I click the custom button, the HTML table is generated correctly, but the Excel file download doesn't seem to work. Could someone kindly review the code snippet above and provide any insights or suggestions on how to troubleshoot and resolve this issue? I would greatly appreciate it. Thank you in advance! Version 12.0 SP8Solved181Views0likes2CommentsError when try to upload a file ARAS 12
When I try to upload a file in my Item Type, I receive the error Multiple Errors: DoPhysicalFiles - SendRequestToVaultServer: invalid_client -, it was working normally, but today start to show this issue. Someone pass by this issue and can help me? Thanks a lot.423Views0likes4CommentsInstruction: Hiding the Open in Office Button
Hello everyone, Here is a short instruction on how to hide the Open in Office (Microsoft Office Connector) Button when viewing document items. This can be done without uninstalling / disabling MSO in case you want to prevent users from using the Toolbar Action button. Before: After: This can be achieved by taking these steps: Go to the root \Innovator installation directory of your Innovator instance Navigate to \Innovator\Client\styles Append common.min.css with the following CSS: [data-id="MSO_OpenInOfficeMenuButton"]{display: none!important;} I recommend also updating the regular common.css file with the same CSS but indented Save, clear browser cache and reload the Innovator webpage I hope this helps. All the best from Almelo. Daan1.9KViews0likes3CommentsLink in children's Item Type view to the parent's Item Type view
Hello everyone, Try explain, my scenario: I have the Item Types related: 1° Item type Authorization. 2° Item type AuthorizationTittle. 3° Item type AuthorizationTittleRelation (only to related). I need add a link or buton in AuthorizationTittle with a phisical link/url to open a view of your Authorization Parent. Thanks.Solved6.2KViews0likes12CommentsARAS 12 - Before saving children's Item Type get the ID of the parent's Item Type
Hello everyone, Try explain, my scenario: I have the Item Types related: 1° Item type Authorization. 2° Item type AuthorizationTittle. 3° Item type AuthorizationTittleRelation (only to related). In the Authorization register view, I have the listing and button/link to register the AuthorizationTittle, the problem is when inserting the AuthorizationTittle, retrieve the id of the parent Authorization and set a field in the AuthorizationTittle to reinforce this FK. I know that this relationship is automatically created in the AuthorizationTittleRelation, the problem is the time, this table is only fed after doing a done on the Authorization parent record, and I need the information of who the AuthorizationTittle parent is before this action.1.3KViews0likes2CommentsHow to display hyperlink for column values on version grid
Itemtype -> navigate -> versions Hello Everybody, I have one custom property displayed on OOTB version grid and I m trying to set it as hyperlink ..Is there any way to do so? Property holds multiple items .(so can't use datatype as Item) Thanks, kara2KViews0likes1CommentDebugging Server Method
Hello All, I am new to Aras. Since I have 15+ experience .net. Willing to learn and get updated. I have download and gone thru programming guide. I have installed and setup Aras Innovator in IIS. I have added element in config file. I am not able to see w3wp.exe in "Attach to Process". I am learning innovator 12 from Demo videos. Can you give me a link of demo video which deals with debugging server method. Could you please help me on this.3KViews0likes3CommentsAras does not send emails
Hi all! For some time now the Aras server has ceased send emails. No errors (even if I set wrong value to "Mail SMTPServer" parameter to InnovatorServerConfig.xml). No connection attempts in the mail server logs. But the emails to be sent appear in the "Innovator\Server\temp" folder on the server. But nothing else happens. It looks like the server is not trying to send them. What can be wrong? Aras 12.0 SP9 free.Solved2.9KViews0likes2Comments
