How to use "In" Operator in TGV query builder
In TGV multi value list datatype is present & we need to filter data based on comma separated selection value. but In operator is not present in where conditions. If we select 1 record it is working fine but if we select multiple record in dropdown it is not working. Regards, Suhas191Views0likes2CommentsGetting Item id from custom context method on Tree Grid View
Hi, I have two new ItemTypes that i use to add project activities and tasks to the Part ItemType like this: I have created a new query definition and tree grid view to display the structure on a new tab on the Part: I have also created a custom context menu item with corresponsing method that is intended to set the Done property on the selected task. The issue i am struggeling with is that i cant get the Item id of the selected row. var taskItem = aras.newIOMItem('Task', 'edit'); var tgvContext = inArgs.contextParams.tgvContext; var tgvGrid = tgvContext.grid; var tgvGridData = tgvContext.getGridData() var dataObject = tgvGridData.focus[0].row.cells[0].data; aras.AlertError("Result: " + dataObject); as shown from the output i get "INVALID_ID_VALUE" Hope somebody can assist here.1.3KViews0likes5CommentsTreeGridView performance
We have "changes" tab to list, in a tree grid view, the change objects which have gone through on a given Part. However, loading this tab is terribly slow. I have found out that the query itself is quite fast. When I run it in the query editor, it takes less than a second. However, the Tree Grid View can take almost 20 seconds to load. Even on a fresh part with no change items, it takes 15+ seconds. The call which takes time is an odata call to /Server/odata/method.rb_GetTreeGridData, which takes the entire 2500+ line rb_TreeGridViewDefinition as input (why? It's a server side method, although a very odd one I can't see the implementation of, and the data it gets passed lives on the server too!) Have anyone had any success in optimizing the loading of tree grid view structures?195Views0likes7CommentsApply Sorting on Tree Grid View
Is there a way to sort rows/content in alphabetical order in tree grid view ?. We have a relationship tab where we add the relationship items , using tree query definition we build a tree grid view but we need to sort the rows in aplbhateical order . does Aras OOTB has this capability ?3.3KViews0likes4Comments
