Date-Time format across ARAS
Hi All, I got an assignment to change the date to universal date format across ARAS environment as below. Format Time format Comment Date: . YYYY-MM-DD Eg. 2025/12/05 Date: . YYYY-MM-DDThh:mm:ssZ Eg. 2025-12-0502:01:15 PM 12-hour format Includes AM/PM Please help where to change this.Solved190Views0likes2CommentsCorporateTimeZone not displayed in Innovator12SP3
Hi Community, I tried to set the time zone in my Innovator 12SP3 test installation, but the time is not displayed in the top right corner. Has someone faced a similar issue and can give me some help? I followed the instructions in the Configuring Internationalization guide. I created new Variable with the following values: Variable: CorporateTimeZone Value: W. Europe Standard Time Default Value: W. Europe Standard Time I then restarted the WWW-publishing service and started the "Update time zone data" action. But after several attempts I still wasn´t able to display the time in the top right corner. I have checked the time zone in my registry (HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Time Zones). My registry doesn´t contain a key that indicates the time zone of my current server. But I am not sure if this is really the main problem. Has anybody an idea what could be missing? Many thanks! Angela3.8KViews0likes1Comment
