- Sathishkumar_CCreator III followed these steps but i didn't get a solution. To set the Corporate Time Zone please use the following steps: 1) Log into Aras Innovator as an Administrator 2) From the TOC, select Administration\Variables 3) From the main toolbar, select “Create a New Item” 4) Set the Name = CorporateTimeZone 5) Set the Value = India Standard Time 6) Save, Unlock, and Close the Variable Item 7) Log out of Aras Innovator 8) Restarted mt IIS server. Help me.
- Yoann_MaingonAccelerator IThis is the right way to do it (you don't even have to restart IIS). Have you actually selected a different timezone on your client to see the difference? I just tested it, my client is on paris timezone and the corporate timezone is India Standard Time and it works. I tested it on 11SP7 but it should work the same way on open releases like SP5 and SP9
