ARAS 31 Self Service report
Hai , I have been looking to generate SSR (Self Service Report in ARAS 31). I have done that in ARAS 11. But In ARAS 31 the features and UI has changed , and lot of options like Filter, Item property ... ect. are not available . Could you please hele me to find a way to create SSR in ARAS 31. Thanks in Advance , Salini202Views0likes3CommentsSelf Service Reporting - Latest Released
I need to pull a report but only for latest released however it seems SSR can only pull current? I've tried messing around with filters on the is_current and is_released properties but when set to 1 and latest isn't one of these I don't get the expected result. Suggestions?2.5KViews0likes12CommentsSelf Service Reporting - Display images on PDF Report
I have a report created using SSRS , one of the properties displayed on the report is of type Image. I am able to see the image on the SSRS report. However when I try to export the report to PDF or Print it , the image is displayed as a link (the vault path). Is this how SSRS behaves or am I missing something ? Is there a way for the image to be displayed on the PDF report? Thanks :)1.8KViews0likes2CommentsSelf Service Reporting
Hi ARAS Experts, I have a question. I have been building some Self Service Reports in an ARAS 11 instance. I think that they could be very useful in our Environment. I have the following questions: Can I E-Mail a URL to the Report. If so how? ( I dont want to use exported pdf ect, I like the dynamic nature of the Report within ARAS) Can I link each row in the table to the associated Item so that it will open up within the same ARAS instance. In "Properties", I have played with the advanced property Settings. I can turn an entry in the table to a Hyperlink that will open a specific Item (FQDN), what I cant do is put the right variable in the URL to link to the associated item.5.6KViews0likes4CommentsActivate Self Service Reporting , Premier Subscription
Hi All, I have Aras.PremierSubscription License activated on my Instance , However my self service reporting is still not active, could someone please help me regarding what else is required to activate the reporting service. Thanks.1.9KViews0likes1CommentSetting currency format in Reporting and in the system generally
I'm working on a Self Service Report which includes a cost column. The standard currency format shows me the £ symbol (GBP) even though I'm sitting in Germany and it should use the € (EUR) symbol. I also can't manually edit the format. Questions: Where does it get the format from? I really hope it's not getting it from my browser settings as that would be very dangerous Is there any way to manually set the number configuration? Just typing into the box doesn't work Where is the system-wide currency set, if possible? Costs, as an item property seem to be without units. I could see this causing confusion in an international setting. Also, the documentation for Self Service Reporting is very weak, just covering the tip of the iceberg of the capabilities. Is there another source of more detailed information? Thank you, Tim3KViews0likes2CommentsSelf Service Reporting , Display Image in Word
Hi , I have a self service report generated with one of the property being of type image. When I try to Export the Report to Word I get the following : Is there any way to get the actual Image in the Report rather than the file path ? Any tips would be helpful. Thanks & Regards, Shruti.1.5KViews0likes0CommentsSelf-Service Reporting Questions
Our business is wanting to start reporting more frequently. I have found that Self-Service Reporting is time-consuming and somewhat troublesome to use...not to mention slow. I have a few questions for those who use the Self-Service Reporting tool in Innovator: Who creates the self-service reports for your business? Is IT involved? Is it a full-time resource? What is the volume of requests for new reports? What areas/ItemTypes of Aras are the reports generated? What is the magnitude of the reports? (i.e. do you have many specific reports for whoever requests them or do you have just a few broad datasets that users can then run filters on to suit their needs?) If you do not utilize Self-Service Reporting, what reporting mechanism does your business use for users to measure metrics, etc? Thank you, in advance, for your response. Wes4.9KViews0likes1Comment
