Tim__Beard
5 years agoIdeator II
Setting currency format in Reporting and in the system generally
I'm working on a Self Service Report which includes a cost column. The standard currency format shows me the £ symbol (GBP) even though I'm sitting in Germany and it should use the € (EUR) symbol. I also can't manually edit the format.
Questions:
- Where does it get the format from? I really hope it's not getting it from my browser settings as that would be very dangerous
- Is there any way to manually set the number configuration? Just typing into the box doesn't work
- Where is the system-wide currency set, if possible? Costs, as an item property seem to be without units. I could see this causing confusion in an international setting.
Also, the documentation for Self Service Reporting is very weak, just covering the tip of the iceberg of the capabilities. Is there another source of more detailed information?
Thank you,
Tim
