UI doesn't load for one user - anyone had a similar problem?
On our test server, on one particular database, one particular user doesn't get an UI when logging in. I've tried digging into the frontend calls, and it seems it's this call: https://{our test server}/Server/MetaData.asmx/GetConfigurableUi?accept=json&database={one particular db}&date=2025-05-02T13%3A01%3A58.94&item_classification=%25all_grouped_by_classification%25&item_type_id=&lang=en&location_name=TOC&user={me} which fails, with a "not a single item" fault. I am in fact logged in, and can e.g. go see the session information on the user button. Deleting all client side caches or logging in with incognito mode makes no difference. Have anyone else experienced this?127Views0likes5CommentsARAS 31 Self Service report
Hai , I have been looking to generate SSR (Self Service Report in ARAS 31). I have done that in ARAS 11. But In ARAS 31 the features and UI has changed , and lot of options like Filter, Item property ... ect. are not available . Could you please hele me to find a way to create SSR in ARAS 31. Thanks in Advance , Salini150Views0likes3CommentsARAS 31 soap-env:server authentication failed for admin authentication failed for admin
Hai, We have upgraded to ARAS 31 from 12. The migration is in progress. While login from application Its working fine. But while login from web API we are getting an error "soap-env:server authentication failed for admin authentication failed for admin" We have tried to give the password in MD5 hash format for username admin. But the error not yet solved. can anyone help us on this? Thanks in advance, Salini273Views0likes6Comments
