FMEA Master
We aim to establish an FMEA Master function. Based on the information in the Master, DQD and PQD can be generated. Updates made in DQD/PQD should be reflected back in the Master, and updates in the Master should in turn propagate to all DQD/PQD generated from it, allowing users to decide whether to apply the updates. Does anyone have any advice on development and data structure design?105Views0likes0CommentsAras Update (Version 1.22.1328.0): Aras Quality Management System (2023 Release 14.0.1) Download Failed
I am unable to download the correct QMS 2023 package through ArasUpdate Tool. Please help. Note: Looks like Process Quality Binding(PQB) package gets downloaded instead of QMS.80Views0likes2CommentsFMEA Reports
Hello, Has any one Developed any report for FMEA using query builder? Assume a Program Object(Custom) Connected with 20 FMEAs which has 2 custom Properties Sub System and Components Use Case is 1 . Create a Report which will take input as RPN > any Number (Example : RPN>40 or RPN>85 etc) and give a report of each lines of FMEA which has matching criteria (RPN> number) . Report Should have Export to excel option. 2. Show the top 50 Critical lines for the Program .That means show a report with all lines having top 50 highest RPNs. I tried Creating this report by writing Custom Code where report is static one and i hard Coded the value in Code with RPN>40 . Also this does not have Export to Excel available. Question is can this report be generated using Query Builder ? Or Self Service Reporting tool will be of any help to build this kind of dynamic report ? Thanks Smruti6.3KViews0likes3Comments
