ECO simpllification
Hi, I simplified the Express ECO workflow. start-->submit-->draft changes-->review-->close change I am using the Express ECO lifecycle : new--> in planning--> in work -->in review--> released there is no problem for parts from Preliminary to Released. But when I try to change a released part, for Express ECO "In Work" state, the part does not go the "In Change" state. I think a confusing situation occurs but I can not find the solution. thanks Duygu1.9KViews0likes0CommentsWork Item - Onclick - Inbasket
Hi all... I have small doubt regarding work item or Workflow Task (At Inbasket). Using WF ,Lifecycle and ItemType.................. One Document is submitted for a review. Now, the document state is "Submitted" Until the Workflow task clicked on Inbasket by assignee it remains "Submitted". If assignee opens the WF Activity completion sheet, the document state is changed into "In Review". After that he may "reject" or "approve". Is it possible?9.3KViews0likes6CommentsLifecycle, Workflow. New ItemType
My requirement: Submit > Review > Verify > Status Created a Lifecycle: Submit > In Verification > Verified > Pending > Closed v v Rejected Unverified Created a Workflow: Start > Review DOC > Verify DOC > Approve > Pending v v Rejected Unverified I have Created a new ItemType called “Docs”. Included “Properties” “RelationshipTypes” “Views - Forms” “Lifecycles - ‘Docs’” Trying to create a workflow related to “Lifecycle - Docs”...... I have defined all “activity” and “promotions” based on the “Lifecycle - Docs”.... When i click “save,unlock&close” it shows following error…. Cannot insert the value NULL into column 'CONTROLLED_ITEMTYPE', table 'InnovatorSolutions.innovator.ACTIVITY_TEMPLATE_TRANSITION'; column does not allow nulls. INSERT fails. The statement has been terminated. in SQL: INSERT INTO [ACTIVITY_TEMPLATE_TRANSITION] ( [BEHAVIOR],[CONFIG_ID],[CONTROLLED_ITEMTYPE],[CREATED_BY_ID],[CREATED_ON],[CURRENT_STATE],[EVENT],[GENERATION],[ID],[IS_CURRENT],[IS_RELEASED],[KEYED_NAME],[LOCKED_BY_ID],[MAJOR_REV],[MANAGED_BY_ID],[MODIFIED_BY_ID],[MODIFIED_ON],[NEW_VERSION],[NOT_LOCKABLE],[OWNED_BY_ID],[PERMISSION_ID],[RELATED_ID],[SORT_ORDER],[SOURCE_ID],[STATE],[TEAM_ID] ) VALUES ( @p0,@p1,@p2,@p3,@p4,@p5,@p6,@p7,@p8,@p9,@p10,@p11,@p12,@p13,@p14,@p15,@p16,@p17,@p18,@p19,@p20,@p21,@p22,@p23,@p24,@p25 ) What is this error? I am new to Aras? Anybody plz help me…...7.3KViews0likes4Comments
