Sathishkumar_C's avatar
Sathishkumar_C
9 years ago
Work Item - Onclick - Inbasket
Hi all... I have small doubt regarding work item or Workflow Task (At Inbasket). Using WF ,Lifecycle and ItemType.................. One Document is submitted  for a review. Now, the document state is "Submitted" Until the Workflow task clicked on Inbasket by assignee it remains "Submitted". If assignee opens the WF Activity completion sheet, the document state is changed into "In Review". After that he may "reject" or "approve". Is it possible?
  • Hi, I'm not sure I get what you are trying to do. If you look at CMII change management processes. The document approval will go through an ECN. Be carefull with workflows on versionable itemtypes, we shouldn't allow it.
  • Can i change the Item State by click (or Opening the task ) at InBasket?
  • From the inbasket, it will open a vote dialog which will potentially allow you to move to another activity in the workflow. Then, potentially if you activated a promotion on the attached lifecycle from the workflow, it can change the state.
  • For example..... Take a one review process... Workflow Activities Submit>Review>Approve or Reject  Lifecycle states Submitted>In Review> Approved or Rejected States: Submitted -> User submit for review. Now Item State is submitted. In review -> The item is at Inbasket of Assignee. Until opening the item, it's state remains as "Submitted". If assignee once opens the activity completion sheet then it automatically promoted as "In Review". Is it Possible?
