Log how many times an item has been opened
Hello, we are looking into measuring how much items/modules are beeing used by our users. I think if you add a client method to a item, that should be no problem with an OnShowItem event and then increase a number on a table somewhere. But is there are global approach that we don't have to insert such a method in each item we want to track? Any ideas are welcome, thanks in advance.302Views0likes7CommentsARAS31 import.mf deployment issue
Hai, We recently upgraded our environment from Aras Innovator 11 to Aras Innovator 31, and we are running into several issues while deploying our solution packages. I wanted to share the details here to see if anyone has faced similar challenges or has suggestions. In Aras 11, we used an import.mf file with the following structure, and everything deployed without issues: <imports> <package name="DatabaseIdentifier" path="com\aras\innovator\DatabaseIdentifier" /> <package name="com.aras.innovator.solution.PLM" path="PLM\Import" /> <package name="com.aras.innovator.solution.Project" path="Project\Import"> <dependson name="com.aras.innovator.solution.PLM" /> </package> <package name="com.aras.innovator.core" path=".\" /> <package name="com.aras.innovator.cui_default" path=".\" /> <package name="Custom_Pkg1" path="CustomPkg1\Import" /> <package name="Custom_Pkg2" path="CustomPkg2\Import" /> </imports> After upgrading to Aras 31, we tried using the same .mf configuration, but we are encountering multiple deployment errors. Issues Observed 1. Null Reference Error Object reference not set to an instance of an object. 2. Method Not Found Error It points to this AML:→ Error: “No items of type Method found.” <Item type='ItemType' id='8052A558B9084D41B9F11805E464F443' action='edit'> <Relationships> <Item type="Server Event" action="add"> <related_id keyed_name="FileOnGet" type="Method"> <Item type="Method" action="get" select="id"> <name>FileOnGet</name> </Item> </related_id> </Item> </Relationships> </Item> Import package 'com.aras.innovator.core' failed with message: No items of type Method not found. 3. Timeout Error During Import The package was then marked as a failed release (seen for custom_Pkg). faultcode: 999 faultstring: System.Net.WebException: The operation has timed out 1. In Aras 31, are we required to use manifest.json instead of the old import.mf format for custom packages? 2. If yes, where exactly should the manifest.json file be placed, and what structure should it follow? 3. How should we handle customizations or extensions to system-level packages like com.aras.innovator.core and com.aras.innovator.cui_default that previously existed in Aras 11? 4. Has anyone encountered the faultcode 999 / timeout issue during import — and how did we resolve it? Thanks in Advance SaliniSolved374Views0likes9CommentsCreating new items via aras.uiShowItemEx doesn´t add LifeCycle data especially for versioned ItemTypes. How to fix?
Hi community, I have a couple of ItemTypes with a custom LifeCycle. Sometimes when users promote an item to change the "state", the Form will not be updated and will not show the updated data. In this case users always had to click the refresh button to see the updated state. So the basic situation is something like this: I discovered that the Form update mainly fails when the item was created via a custom client Method. AND: In addition it only fails if the target ItemType is versionable. Here are some simple steps to reproduce the scenario. Let´s assume we have following code that we can directly execute from a client Method: [embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:19604769-ada7-4f06-92ad-60eb8ae9dadd:type=text&text=const%20newItem%20%3D%20aras.newItem%28%22Manufacturer%22%2C%22add%22%29%3B%0Aaras.uiShowItemEx%28newItem%2C%20%22tab%20view%22%29%3B] The code will add a new item and opens it in a new tab. User than can save the item and promote it to another state. - If the ItemType is something like Manufacturer, Form update will work after item promotion. - If the ItemType is versionable like Part or Document the Form update will NOT work. I checked the context item that is used for promotion. I noticed that for versionable items the LifeCycle data is not included in the context item when we come from a custom Method. When using promote, the context item should contain information about the used LifeCycle like this: But the life cycle State information is missing when promoting a versionable item that was created by Method I wonder if this is a bug in innovator or if I forgot something in my Method code. The update error does not occur for of items that were created via the regular "New item" button. I assume the missing LifeCycle data causes the problems with the Form update. Does anyone know how to improve this one? Thanks for any hint! AngelaSolved179Views0likes1CommentHow to change the position of a Relationship Accordion tab
I needed to make a tab visible to certain identity. Therefore, I selected "Hide All" in the relationship types and used the CUI control to make a new tab. I need this tab to be all the way to right. Sort Order fields don't work, neither in the Relationship Type nor in cui_windowSection. Pictures below186Views0likes3CommentsHow to hide a tab of an item?
For the Item Part, for the all the part numbers, I need to hide a specific tab, lets say "Goals" for a specific identity. "Goals" is under Relationship Types in Part item. I have tried: - Right click on the Goals in Relationship Type,Permissions--> Access Report, edit Permissions named "Relationship Type". Add identity, here to Permission named "RelationshipType" and give no rights to the identity. The tab still shows.176Views0likes2CommentsHow to disable delete relationship button based on parent item state?
I know this question has been asked multiple times and I have reviewed all the ones that had answers. None of them seemed to clearly lead me in the right direction. I feel what I'm trying to do is a pretty basic use case. I'm trying to prevent affected items from being deleted or added based on the lifecycle state of the ECN. I feel the following is the most user friendly way to achieve this. For the ECN Item, I want to disable the "Delete ECN Affected Item" button when the ECN state is (In Review or Released state). Is this recommended? If so, please provide an example. If not, what is the preferred method to achieve this with a good user experience?Solved398Views0likes6CommentsI want to see all item bout related item in relationship tab
I developing a request form When I make a Item to request I want to a view a bout the item that I can request I manage the Item list by a Item type And I make a relationship type to connect the request item type and item list item type I need how to view all of the Item in my relationship tab bout the related item type I using aras 1233Views0likes0CommentsHow can I prevent that users accidentally close an element in the tab bar? (TOC View with Form)
Hi community, I right now work on a MES scenario were I use a TOC View as interface for end users. For some specific use cases (parallel work) I allow that user use multiple instances of the same TOC View in parallel. As user may work with a couple of these tabs at the same time, I want to prevent that they accidentally close any of the tabs. They of course can open the TOC View again and continue were they stopped. But it would add a some comfort if a warning message appears where users can decide if they really want to close the tab. I tried to use an "onBeforeUnload" Method on my Form that returns "true" or "false". The "false" is some kind of accepted by Innovator, as it will then throw me the "Item not saved" error message. But it will still close the tab independent from the user selection. Does anyone know a simple solution to prevent closing a tab? Every idea is welcomed!! :-) Thanks! Angela714Views0likes1CommentTrigger Client Method on Relationship Replace
I have a client method defined to be triggered on an OnInsertRow event for the Part BOM relationship type. This method is not triggered when the user performs a Part BOM replace. The most likely reason for this is, when handling the replace Innovator is just doing an update of the Part BOM item. The Part BOM itemtype definition only allows OnBeforeNew, OnAfterNew, OnNew and OnShowItem client events. But these events are not triggered when doing a Part BOM replace. Is there any way to trigger a client method when doing a Part BOM replace?1.7KViews0likes2Comments
