Custom check Failed while update package
Hello, I installed Aras from www.aras.com/.../ and also installed aras update for updating package. I wanted to add package in to system. It through error as "Custom check Failed". [START LOG] 2018-02-07 02:01:15,157 [INFO ] (1) - Checking package started: 'C:\ProgramData\Aras\ArasUpdate\PE\11.0.1008\package.config' 2018-02-07 02:01:15,266 [INFO ] (1) - Checking package finished 2018-02-07 02:01:15,625 [INFO ] (1) - Checking package started: 'C:\ProgramData\Aras\ArasUpdate\PQB\11.0.1008\package.config' 2018-02-07 02:01:15,656 [INFO ] (1) - Checking package finished 2018-02-07 02:01:15,656 [INFO ] (1) - Checking package started: 'C:\Users\Administrator\Downloads\Aras Partner Demo Environment - 11 SP11\package.config' 2018-02-07 02:01:15,797 [INFO ] (1) - Checking package finished 2018-02-07 02:01:22,703 [INFO ] (1) - Checking package started: 'C:\ProgramData\Aras\ArasUpdate\PE\11.0.1008\package.config' 2018-02-07 02:01:22,703 [INFO ] (1) - Checking package finished 2018-02-07 02:01:22,703 [INFO ] (1) - Checking package started: 'C:\ProgramData\Aras\ArasUpdate\PQB\11.0.1008\package.config' 2018-02-07 02:01:22,719 [INFO ] (1) - Checking package finished 2018-02-07 02:01:47,377 [INFO ] (1) - Checking package started: 'C:\Demo\package.config' 2018-02-07 02:01:48,281 [INFO ] (1) - Checking package finished 2018-02-07 02:01:48,297 [INFO ] (1) - Checking package started: 'C:\Demo\package.config' 2018-02-07 02:01:48,470 [INFO ] (1) - Checking package finished 2018-02-07 02:01:48,516 [INFO ] (1) - Checking package started: 'C:\ProgramData\Aras\ArasUpdate\PE\11.0.1008\package.config' 2018-02-07 02:01:48,531 [INFO ] (1) - Checking package finished 2018-02-07 02:01:48,531 [INFO ] (1) - Checking package started: 'C:\ProgramData\Aras\ArasUpdate\PQB\11.0.1008\package.config' 2018-02-07 02:01:48,547 [INFO ] (1) - Checking package finished 2018-02-07 02:01:48,547 [INFO ] (1) - Checking package started: 'C:\Demo\package.config' 2018-02-07 02:01:48,656 [INFO ] (1) - Checking package finished 2018-02-07 02:03:11,042 [INFO ] (7) - Checking package started: 'C:\Demo\package.config' 2018-02-07 02:03:11,177 [INFO ] (7) - Checking package finished 2018-02-07 02:03:25,862 [WARN ] (7) - Custom check failed. 2018-02-07 02:03:27,455 [WARN ] (7) - Custom check failed. 2018-02-07 02:03:27,457 [ERROR] (7) - Aras.Tools.ArasUpdateCore.Implementations.Commands.CheckCompatibilityPackageCommand: Custom check failed.Custom check failed. 2018-02-07 02:03:27,476 [INFO ] (7) - Operation 'Install' failed 2018-02-07 02:04:48,108 [INFO ] (1) - Checking package started: 'C:\ProgramData\Aras\ArasUpdate\PE\11.0.1008\package.config' 2018-02-07 02:04:48,117 [INFO ] (1) - Checking package finished 2018-02-07 02:04:48,121 [INFO ] (1) - Checking package started: 'C:\ProgramData\Aras\ArasUpdate\PQB\11.0.1008\package.config' 2018-02-07 02:04:48,132 [INFO ] (1) - Checking package finished 2018-02-07 02:04:48,136 [INFO ] (1) - Checking package started: 'C:\Demo\package.config' 2018-02-07 02:04:48,286 [INFO ] (1) - Checking package finished 2018-02-07 02:04:57,955 [INFO ] (10) - Checking package started: 'C:\Demo\package.config' 2018-02-07 02:04:58,156 [INFO ] (10) - Checking package finished 2018-02-07 02:04:58,364 [INFO ] (10) - Installation of the package started : 'Demo 11SP11' from 'C:\Demo' directory 2018-02-07 02:04:58,365 [INFO ] (10) - CompatibilityPackage started 2018-02-07 02:04:58,716 [INFO ] (10) - Checking module 'CF' compatibility. 2018-02-07 02:04:59,645 [INFO ] (10) - LoadFile started 2018-02-07 02:04:59,651 [INFO ] (10) - Loading File : 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\scripts\include/rev.inc'. 2018-02-07 02:04:59,651 [INFO ] (10) - LoadFile finished 2018-02-07 02:05:00,048 [INFO ] (10) - LoadFile started 2018-02-07 02:05:00,050 [INFO ] (10) - Loading File : 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\scripts\include\build.inc'. 2018-02-07 02:05:00,051 [INFO ] (10) - LoadFile finished 2018-02-07 02:05:01,155 [INFO ] (10) - [echo] The target Aras instance is not compatible with this package. 2018-02-07 02:05:01,498 [INFO ] (10) - [echo] Required: 11.0 SP11 (6812) 2018-02-07 02:05:01,858 [INFO ] (10) - [echo] Found: 11.0 SP12 (6920,11.0.0.6920,11.0.0.6920) 2018-02-07 02:05:01,859 [INFO ] (10) - Custom started 2018-02-07 02:05:01,860 [INFO ] (10) - Custom finished 2018-02-07 02:05:02,967 [INFO ] (10) - Custom started 2018-02-07 02:05:02,968 [INFO ] (10) - Custom check the property : 'ConversionServerIsInstalled'. The value : 'true'. 2018-02-07 02:05:02,968 [INFO ] (10) - Custom finished 2018-02-07 02:05:03,507 [INFO ] (10) - Custom started 2018-02-07 02:05:03,531 [INFO ] (10) - Custom check the property : 'AgentServiceIsInstalled'. The value : 'true'. 2018-02-07 02:05:03,533 [INFO ] (10) - Custom finished 2018-02-07 02:05:04,679 [INFO ] (10) - Custom started 2018-02-07 02:05:04,682 [INFO ] (10) - Custom check the property : 'SsrIsInstalled'. The value : 'true'. 2018-02-07 02:05:04,683 [INFO ] (10) - Custom finished 2018-02-07 02:05:04,684 [WARN ] (10) - Custom check failed. 2018-02-07 02:05:04,820 [INFO ] (10) - Checking module 'IS' compatibility. 2018-02-07 02:05:05,222 [INFO ] (10) - [echo] [prop] Inn.Dir = C:\Program Files (x86)\Aras\Innovator\Innovator 2018-02-07 02:05:05,298 [INFO ] (10) - LoadFile started 2018-02-07 02:05:05,299 [INFO ] (10) - Loading File : 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\scripts\include/rev.inc'. 2018-02-07 02:05:05,300 [INFO ] (10) - LoadFile finished 2018-02-07 02:05:05,445 [INFO ] (10) - LoadFile started 2018-02-07 02:05:05,448 [INFO ] (10) - Loading File : 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\scripts\include\build.inc'. 2018-02-07 02:05:05,449 [INFO ] (10) - LoadFile finished 2018-02-07 02:05:05,703 [INFO ] (10) - [echo] The target Aras instance is not compatible with this package. 2018-02-07 02:05:05,802 [INFO ] (10) - [echo] Required: 11.0 SP11 (6812) 2018-02-07 02:05:05,886 [INFO ] (10) - [echo] Found: 11.0 SP12 (6920,11.0.0.6920,11.0.0.6920) 2018-02-07 02:05:05,887 [INFO ] (10) - Custom started 2018-02-07 02:05:05,888 [INFO ] (10) - Custom finished 2018-02-07 02:05:06,225 [INFO ] (10) - Custom started 2018-02-07 02:05:06,266 [INFO ] (10) - Custom check the property : 'ConversionServerIsInstalled'. The value : 'true'. 2018-02-07 02:05:06,267 [INFO ] (10) - Custom finished 2018-02-07 02:05:06,267 [WARN ] (10) - Custom check failed. 2018-02-07 02:05:06,268 [INFO ] (10) - CompatibilityPackage finished 2018-02-07 02:05:06,269 [ERROR] (10) - Aras.Tools.ArasUpdateCore.Implementations.Commands.CheckCompatibilityPackageCommand: Custom check failed.Custom check failed. 2018-02-07 02:05:06,270 [INFO ] (10) - Operation 'Install' failed 2018-02-07 02:05:09,946 [INFO ] (1) - Checking package started: 'C:\ProgramData\Aras\ArasUpdate\PE\11.0.1008\package.config' 2018-02-07 02:05:09,959 [INFO ] (1) - Checking package finished 2018-02-07 02:05:09,963 [INFO ] (1) - Checking package started: 'C:\ProgramData\Aras\ArasUpdate\PQB\11.0.1008\package.config' 2018-02-07 02:05:09,976 [INFO ] (1) - Checking package finished 2018-02-07 02:05:09,979 [INFO ] (1) - Checking package started: 'C:\Demo\package.config' 2018-02-07 02:05:10,125 [INFO ] (1) - Checking package finished 2018-02-07 02:15:32,973 [INFO ] (5) - Checking package started: 'C:\Demo\package.config' 2018-02-07 02:15:33,133 [INFO ] (5) - Checking package finished 2018-02-07 02:15:33,402 [INFO ] (5) - Installation of the package started : 'Demo 11SP11' from 'C:\Demo' directory 2018-02-07 02:15:33,403 [INFO ] (5) - CompatibilityPackage started 2018-02-07 02:15:33,766 [INFO ] (5) - Checking module 'CF' compatibility. 2018-02-07 02:15:34,843 [INFO ] (5) - LoadFile started 2018-02-07 02:15:34,844 [INFO ] (5) - Loading File : 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\scripts\include/rev.inc'. 2018-02-07 02:15:34,845 [INFO ] (5) - LoadFile finished 2018-02-07 02:15:35,194 [INFO ] (5) - LoadFile started 2018-02-07 02:15:35,196 [INFO ] (5) - Loading File : 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\scripts\include\build.inc'. 2018-02-07 02:15:35,197 [INFO ] (5) - LoadFile finished 2018-02-07 02:15:36,214 [INFO ] (5) - [echo] The target Aras instance is not compatible with this package. 2018-02-07 02:15:36,571 [INFO ] (5) - [echo] Required: 11.0 SP11 (6812) 2018-02-07 02:15:36,947 [INFO ] (5) - [echo] Found: 11.0 SP12 (6920,11.0.0.6920,11.0.0.6920) 2018-02-07 02:15:36,948 [INFO ] (5) - Custom started 2018-02-07 02:15:36,948 [INFO ] (5) - Custom finished 2018-02-07 02:15:37,788 [INFO ] (5) - Custom started 2018-02-07 02:15:37,788 [INFO ] (5) - Custom check the property : 'ConversionServerIsInstalled'. The value : 'true'. 2018-02-07 02:15:37,789 [INFO ] (5) - Custom finished 2018-02-07 02:15:38,485 [INFO ] (5) - Custom started 2018-02-07 02:15:38,487 [INFO ] (5) - Custom check the property : 'AgentServiceIsInstalled'. The value : 'true'. 2018-02-07 02:15:38,488 [INFO ] (5) - Custom finished 2018-02-07 02:15:39,700 [INFO ] (5) - Custom started 2018-02-07 02:15:39,701 [INFO ] (5) - Custom check the property : 'SsrIsInstalled'. The value : 'true'. 2018-02-07 02:15:39,701 [INFO ] (5) - Custom finished 2018-02-07 02:15:39,702 [WARN ] (5) - Custom check failed. 2018-02-07 02:15:39,776 [INFO ] (5) - Checking module 'IS' compatibility. 2018-02-07 02:15:40,102 [INFO ] (5) - [echo] [prop] Inn.Dir = C:\Program Files (x86)\Aras\Innovator\Innovator 2018-02-07 02:15:40,195 [INFO ] (5) - LoadFile started 2018-02-07 02:15:40,196 [INFO ] (5) - Loading File : 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\scripts\include/rev.inc'. 2018-02-07 02:15:40,277 [INFO ] (5) - LoadFile finished 2018-02-07 02:15:40,359 [INFO ] (5) - LoadFile started 2018-02-07 02:15:40,360 [INFO ] (5) - Loading File : 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\scripts\include\build.inc'. 2018-02-07 02:15:40,361 [INFO ] (5) - LoadFile finished 2018-02-07 02:15:40,731 [INFO ] (5) - [echo] The target Aras instance is not compatible with this package. 2018-02-07 02:15:40,816 [INFO ] (5) - [echo] Required: 11.0 SP11 (6812) 2018-02-07 02:15:40,902 [INFO ] (5) - [echo] Found: 11.0 SP12 (6920,11.0.0.6920,11.0.0.6920) 2018-02-07 02:15:40,903 [INFO ] (5) - Custom started 2018-02-07 02:15:40,904 [INFO ] (5) - Custom finished 2018-02-07 02:15:41,154 [INFO ] (5) - Custom started 2018-02-07 02:15:41,155 [INFO ] (5) - Custom check the property : 'ConversionServerIsInstalled'. The value : 'true'. 2018-02-07 02:15:41,156 [INFO ] (5) - Custom finished 2018-02-07 02:15:41,156 [WARN ] (5) - Custom check failed. 2018-02-07 02:15:41,160 [INFO ] (5) - CompatibilityPackage finished 2018-02-07 02:15:41,160 [ERROR] (5) - Aras.Tools.ArasUpdateCore.Implementations.Commands.CheckCompatibilityPackageCommand: Custom check failed.Custom check failed. 2018-02-07 02:15:41,162 [INFO ] (5) - Operation 'Install' failed 2018-02-07 02:28:10,616 [INFO ] (1) - Checking package started: 'C:\ProgramData\Aras\ArasUpdate\PE\11.0.1008\package.config' 2018-02-07 02:28:10,628 [INFO ] (1) - Checking package finished 2018-02-07 02:28:10,632 [INFO ] (1) - Checking package started: 'C:\ProgramData\Aras\ArasUpdate\PQB\11.0.1008\package.config' 2018-02-07 02:28:10,646 [INFO ] (1) - Checking package finished 2018-02-07 02:28:10,650 [INFO ] (1) - Checking package started: 'C:\Demo\package.config' 2018-02-07 02:28:10,815 [INFO ] (1) - Checking package finished [END LOG]3.8KViews0likes4CommentsMAC Policy Issue in ARAS 31 – Need Help with Access Restrictions
Hi all, I’m working on implementing access restrictions for the a Itemtype in ARAS 31. There are around 46 records, and I want to group them into 5 categories. Each category will be assigned to specific identities, allowing controlled access based on the record's classification. To achieve this, I started configuring MAC policies. However, I’ve run into a few issues: The fields I need are disabled in the MAC Policy Condition Editor. User-defined properties are not accessible in the condition editor either. Has anyone faced similar challenges or found a workaround for this? Any help or guidance would be greatly appreciated! Thanks, Salini199Views0likes2CommentsHTTP Error 500.19 - Internal Server Error
This error hits while installing the ARAS innovator, if User done install the .Net Hosting bundle. The solution was to download and install the MS .Net 8.0 Hosting bundle from below link. HTTP Error 500.19 after installing Innovator 2025 - Solved - Getting Started - Aras Community - Aras Community100Views0likes0Comments
