When exposing the affected items tab on express eco I get TypeError: Cannot create property 'width' on string 'image'
Any ideas on how to resolve this? It doesn't seem to affect anything other than UI response after it appears but it is quite an annoyance to anyone that clicks on the tab. I am trying to display some properties for review.3.5KViews1like7CommentsChange ItemType and Affected Item
Good day all. I am working on modifying our change ItemTypes (don't use the OOTB ones). I have been looking at the Simple ECO as an example. Our current changes are associated to a single document/part. So if someone is updating a drawing that affects a part, they would have to submit two changes, it gets worse if this affects multiple things. I would like to modify (or create a new ItemType) these changes to have the Affected Items tab. I have been testing this with a custom ItemType, but am running into problems with the Has Changes getting updated. I looked at Changes Pending in Part post and saw that there were a few Methods that I needed to look at. I modified the Methods PE_update_has_change_pending and PE_ChangeItemTransition to include my change ItemType, but my test document will not get marked as Change Pending. I tested the Simple ECO and it does mark the document. Thank you for any help you can provide.Solved5.9KViews1like6Comments
