HTTP Error 500.19 - Internal Server Error
This error hits while installing the ARAS innovator, if User done install the .Net Hosting bundle. The solution was to download and install the MS .Net 8.0 Hosting bundle from below link. HTTP Error 500.19 after installing Innovator 2025 - Solved - Getting Started - Aras Community - Aras Community77Views0likes0CommentsCompatibility of IOM.dll with .NET Core 8
Hello Innovators, I am currently trying to integrate the IOM.dll with .NET Core 8. Has anyone successfully managed to get it working? If not, are there any recommended workarounds or alternative approaches? Looking forward to your insights. Best regards, DaanSolved56Views0likes1CommentHow to load aras 2023 dll with cpp host cli without native net core?
[embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:4aacaea8-0c4c-471c-aefc-402fbf171d8a:type=text&text=%23using%20%22C%3A%2Ftemp%2Faras2023dlls%2Fbin%2FIOM.dll%22%0D%0A%23using%20%22C%3A%2Ftemp%2Faras2023dlls%2Fbin%2FSystem.Configuration.ConfigurationManager.dll%22%0D%0A%23using%20%22C%3A%2Ftemp%2Faras2023dlls%2Fbin%2FAras.Net.dll%22%0D%0A%0D%0Ausing%20namespace%20System%3B%0D%0Ausing%20namespace%20System%3A%3AIO%3B%0D%0Ausing%20namespace%20System%3A%3AReflection%3B%0D%0Ausing%20namespace%20System%3A%3AConfiguration%3B%20%20%0D%0A%0D%0A%0D%0Avoid%20arasDo%28%29%0D%0A%7B%0D%0A%20%20%2F%2F%20sample%20aras%20code%0D%0A%20%20System%3A%3AString%20%5E%20url%20%3D%20%22http%3A%2F%2Fdevaras2023%2FInnovatorServer%2FServer%2FInnovatorServer.aspx%22%3B%0D%0A%20%20System%3A%3AString%20%5E%20database%20%3D%20%22InnovatorSolutions%22%3B%0D%0A%20%20System%3A%3AString%20%5E%20user%20%3D%20%22admin%22%3B%0D%0A%20%20System%3A%3AString%20%5E%20password%20%3D%20%22innovator%22%3B%0D%0A%0D%0A%20%0D%0A%20%20auto%20conn%20%3D%20Aras%3A%3AIOM%3A%3AIomFactory%3A%3ACreateHttpServerConnection%28url%2C%20database%2C%20user%2C%20password%29%3B%0D%0A%20%20auto%20result%20%3D%20conn-%3ELogin%28%29%3B%0D%0A%20%20auto%20s%20%3D%20result-%3EToString%28%29%3B%0D%0A%7D%0D%0A%0D%0Astatic%20Assembly%20%5E%0D%0A%20%20LoadFromSameFolder%28Object%20%5E%20sender%2C%20ResolveEventArgs%20%5E%20args%29%20%7B%0D%0A%20%20%20%20String%20%5E%20folderPath%20%3D%20%22C%3A%5C%5Ctemp%5C%5Caras2023dlls%5C%5Cbin%22%3B%0D%0A%20%20%20%20String%20%5E%20assemblyPath%20%3D%20Path%3A%3ACombine%28folderPath%2C%20%28gcnew%20AssemblyName%28args-%3EName%29%29-%3EName%20%2B%20%22.dll%22%29%3B%0D%0A%20%20%20%20if%20%28File%3A%3AExists%28assemblyPath%29%20%3D%3D%20false%29%0D%0A%20%20%20%20%20%20return%20nullptr%3B%0D%0A%20%20%20%20Assembly%20%5E%20assembly%20%3D%20Assembly%3A%3ALoadFrom%28assemblyPath%29%3B%0D%0A%20%20%20%20return%20assembly%3B%0D%0A%20%20%7D%0D%0A%0D%0Avoid%20aras%28%29%0D%0A%7B%0D%0A%20%20%2F%2F%20put%20this%20somewhere%20you%20know%20it%20will%20run%20%28early%2C%20when%20the%20DLL%20gets%20loaded%29%0D%0A%20%20System%3A%3AAppDomain%20%5E%20currentDomain%20%3D%20AppDomain%3A%3ACurrentDomain%3B%0D%0A%20%20currentDomain-%3EAssemblyResolve%20%2B%3D%20gcnew%20ResolveEventHandler%28LoadFromSameFolder%29%3B%0D%0A%20%20arasDo%28%29%3B%0D%0A%7D] The exePath does not exist Assembly.GetEntryAssembly() returns a NULL Can someone explain me how to execute the added cpp sample code so I can load the aras 2023 dlls?59Views0likes2Comments"Classification cannot be changed after saving the item" error using the .Net API to update requirement
I am using Aras 11 SP15. I am trying to update a requirement I created. Here is my code: using System; using System.Collections.Generic; using Aras.IOM; namespace TestArasProject { public static class Program { public static void Main(string[] args) { HttpServerConnection conn = IomFactory.CreateHttpServerConnection(serverUrl, dbName, username, password); Innovator inn = IomFactory.CreateInnovator(conn); conn.Login(); Item updateItem = inn.newItem(requirement, "edit"); string internalId = "FB20D91203DC4E3EB30DBA0CFBE4FD0F"; updateItem.setAttribute("where", "[" + requirement.Replace(' ', '_') + "]." + "config_id" + " = '" + internalId + "' AND [" + requirement.Replace(' ', '_') + "]." + "is_current" + "='1'"); // updating the name of the requirement updateItem.setProperty("req_rm_title", "Test Requirement" + Guid.NewGuid()); Item result = updateItem.apply(); Console.WriteLine(result); Console.WriteLine(result.isError()); Console.ReadLine(); conn.Logout(); } } } I am getting the following error: <SOAP-ENV:Envelope xmlns:SOAP-ENV="">schemas.xmlsoap.org/.../" xmlns:i18n="">www.aras.com/I18N"><SOAP-ENV:Body><SOAP-ENV:Fault> <faultcode>1</faultcode> <faultactor /> <faultstring>Classification cannot be changed after saving the item.</faultstring></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope> I checked the XML which was getting created to update, this XML did not even contain the Classification property nor am I trying to update it. Here is the XML: <Item isNew=\"1\" isTemp=\"1\" type=\"re_Requirement\" action=\"edit\" where=\"[re_Requirement].config_id = '3AFD850B785E43F1B854EE404469FA87' AND [re_Requirement].is_current='1'\"> <req_title>2019_06_24_12_25_42_850_-{AB}</req_title> </Item> I noticed that Classification (Type) is a default value on UI still I need to explicitly pass it through the API. This is not the case with Risk or Complexity type of fields. How do I update a requirement?20KViews0likes14CommentsAras.OAuth.Model error when trying to connect using IOM.dll in a .Net Core app
I'm trying to integrate the IOM.dll into a .net core application and I get the error below. "Could not load file or assembly 'Aras.OAuth.Model, Version=12.0.0.21092, Culture=neutral, PublicKeyToken=524d880b05474146'. The system cannot find the file specified." I have the following code with the variable values changed: string serverUrl = "">server/.../InnovatorServer.aspx"; string database = "DataBaseName"; string userName = "user"; string password = "userPassword"; HttpServerConnection connection = IomFactory.CreateHttpServerConnection( serverUrl, database, userName, password); Item loginResult = connection.Login(); //Get Error Here Innovator inn = IomFactory.CreateInnovator(connection); I have added the IOM.dll, Aras.Net.dll, and Aras.Diagnostics.dll as refrences from the Aris installation folder, and added a using Aras.IOM.2.6KViews0likes1CommentTimestamp error after applying 11.0 SP10 patch
Looking for some help. I was following along with the instructions in the "Upgrade from Version 11.0 SP8 to Version 11.0 SP10" directions, and I got to the point where you copy the contents of the .zip over tot he innovator and vault folder, re-set IIS portion and I have run into an issue. The application will no longer display a login, and any attempt to login to a db shown by the the "aras innovator solutionupgrade" (import.exe), I am met with this error: Login errors ****ErrorMessage**** faultstring: Failed login to Innovator; original error: SOAP-ENV:ServerThe type initializer for 'Aras.I18NUtils.TimeZoneInformation' threw an exception.The type initializer for 'Aras.I18NUtils.TimeZoneInformation' threw an exception. faultdetail:Failed login to Innovator; original error: SOAP-ENV:ServerThe type initializer for 'Aras.I18NUtils.TimeZoneInformation' threw an exception.The type initializer for 'Aras.I18NUtils.TimeZoneInformation' threw an exception. Unable to login. faultcode: -100 ******************* Any tips on what setting I should be looking to change? There was something about changing the time zone settings inside the aras application, but since it won't launch...4.6KViews0likes2Comments
