9 years ago
Resource with key="'login.version_html'" is not found
Hi, I have installed Aras 10 SP 9 on my Windows 10 box. However, when I try to open it I get the following error in Firefox:  And in Chrome:  i.e. it says:
Resource with key="'login.login_btn_label'" is not found in "">localhost/.../ui_resources.xml".Resource with key="'login.cancel_btn_label'" is not found in "">localhost/.../ui_resources.xml".
Find the latest version of Aras Innovator
Resource with key="'login.version_html'" is not found in "">localhost/.../ui_resources.xml". 11.0 SP9; Resource with key="'login.build_html'" is not found in "">localhost/.../ui_resources.xml". 6549
How do I solve this?
  • Excuse me, I did of course intend to say Aras PLM version 11 (not 10).
  • can you describe your configuration? IIS? ASP enabled? what is Windows 10 "Box"? is a professionnal version (I think family doesn't have IIS)
  • Hi, thanks for your reply. Yes, I have enabled both IIS and ASP.NET under "Turn Windows features on or off". The OS is Windows 10 Pro, version 10.0.15063 Build 15063. It's my development machine (laptop).
  • When I open "">localhost/.../ui_resources.xml" in the browser and check the source code, it's just blank. Can that have something to do with it?
  • The response when accessing the ui_resource.xml was just blank, and the response code 200. I then found this thread with a solution: stackoverflow.com/.../why-does-iis-return-empty-responses Basically, what you have to do is to enable Static Content in IIS:  Furthermore, you must clear the browser's cache. Lastly, you might need to reboot the computer, but probably not.
