9 years agoAccelerator III
The response when accessing the ui_resource.xml was just blank, and the response code 200. I then found this thread with a solution: stackoverflow.com/.../why-does-iis-return-empty-responses
Basically, what you have to do is to enable Static Content in IIS:
Furthermore, you must clear the browser's cache.
Lastly, you might need to reboot the computer, but probably not.
